BUG
In some cases, a point from a point feature class loaded into a network location may appear on the wrong side.
For example the point being loaded is on the right side of an edge. The resulting network location's SideOfEdge field also says it is on the right side. However, the network location's geometry may be repositioned on the left side of the edge.
This problem can occur when the street network and the point feature class have different spatial references with significantly different precisions. The SideOfEdge (and other network location fields) is being calculated prior to the geometry being snapped to the spatial reference of the network.
Get help from ArcGIS experts
Download the Esri Support App
