BUG
Selecting records on a joined table using the 'Keep only matching records' option crashes ArcMap
This issue is addressed in ArcGIS 9.0 Service Pack 3 (SP3).
If a table was joined to a shapefile using the 'Keep only matching records' option, and a definition query was created using fields from both the table and the shapefile, then attempting to select records within the shapefile attribute table crashed ArcMap.
Cause
This is a known issue.
Workaround
Click on the link in Related Information below for Service Pack 3, if necessary.
    Article ID:000007789
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
