BUG
Sometimes the enumeration esriNetworkAttribuiteUnits is used instead of esriNetworkAttributeUnits by the C# code completion algorithm. This misspelling can lead to type mismatches later in the code.
The enumeration esriNetworkAttributeUnits has a typo in its OLB so that it is also referenced as esriNetworkAttribuiteUnits. This causes the code completion of some programming languages to use the incorrect enumeration name.
Get help from ArcGIS experts
Download the Esri Support App
