BUG
Generating full data cache for elevation layers with layer visibility off creates an empty data cache
This issue is addressed in ArcGIS 9.0 Service Pack 3 (SP3).
When generating full data cache for elevation layers with the application setting for layer visibility off, the result is an empty data cache and subsequently, a corrupt data display.
If the data is visible or there was already a visible layer in the document, the problem will not occur.
Cause
This is a known issue.
Workaround
Click on the link in Related Information below for Service Pack 3, if necessary.
    Article ID:000007774
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
