Frequently asked question
Can the scale of an existing metafile be increased or decreased on output in ARCINFO?
Answer
Yes. Several ARCINFO plotting commands, such as HPGL2, COLORHCBS and POSTSCRIPT, enable an increase or decrease of output size when processing an existing map metafile. The ARCPLOT command PLOT can also be used with the BOX option to create another metafile.
Note that increasing or decreasing the size of the map may cause information on the map to be inaccurate, such as scale information.
Article ID:000007756
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
