English
Error: SE_stream_execute ERROR on SE_STREAM: SE_NET_FAILURE (-10)
Error Message
** This issue is addressed in ArcSDE 9.0 Service Pack 3 (SP3) **
When using shared log file settings and inserting records, the following error message may occur:
"SE_stream_execute ERROR on SE_STREAM: SE_NET_FAILURE (-10)"
Cause
This is a known issue.
Solution or Workaround
** This issue has been addressed in ArcSDE 9.0 Service Pack 3 (SP3)
Click on the link in Related Information below to download the Service Pack, if necessary. **
    Related Information
