PROBLEM
Maps print with horizontal banding and unexpected shading
Maps may print with unwanted horizontal banding and unexpected shading when printed with HPGL2, COLORHCBS and POSTSCRIPT.
Cause
The IMAGE RESOLUTION is too low for the image data.
Solution or Workaround
Assign a value to the driver (HPGL2, COLORHCBS, PostScript) option IMAGE RESOLUTION. Use a value higher than the default of the intended output device. For example, the HP650 default is 300, so use 400.
    Article ID:000007749
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
