HOW TO
Set up order in which parameters appear in the Model dialog box
Summary
Instructions provided describe how to specify the order input parameters appear in the Model dialog box that appears when double-clicking a Model in ArcToolbox and launching the Model.
Procedure
Follow the steps below.
  1. After the flow of the model is set up and its parameters are designated, open the Model > Model > Model Properties.
  2. Click the Parameters tab.
  3. Click the '+' button.
  4. Select the necessary parameters from the list for setting up the order.
    Hold the SHIFT key and click each item to select more than one.
  5. After the desired parameters are selected, click the UP or DOWN arrow keys to move it up and down in the order listed.
  6. Repeat, if desired, step 6 with other parameters.
  7. Click OK.
  8. Click Save.
  9. Double-click on the Model from ArcToolbox to open up the Model dialog box. The order of the parameters shown here reflect the order the parameters were specified in the Model Properties.
Article ID:000007744
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
