BUG
Simple Data Loader does not work on relationship classes
Data containing relationship classes cannot be loaded using the Simple Data Loader.
Cause
Relationship classes constitute non-simple data, so the Simple Data Loader is not able to work with it.
Workaround
Use the Object Loader to load data containing relationship classes into ArcGIS.
Instructions for use of the Object Loader may be found in the ArcGIS Desktop Help under 'Building a geodatabase > Importing data > Loading data in ArcMap'.
Article ID:000007742
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
