ERROR
ora-60 deadlock detected
Error Message
When creating a geometric network it is possible to encounter the Oracle error:
"ora-60 deadlock detected"
This occurs when using the LOB storage type for the logical network.
Additional information is present in the sde.errlog: S_update_attr_LOBS::OCILobWrite error (-51)
Additional information is also present in the Oracle alert log:
ORA-000060 Deadlock detected. More info in file <path>/<name>.trc
Cause
The cause of the problem is Oracle bug '3166756 Self deadlock (ORA-60) possible on LOB index update'.
See Oracle's Metalink for additional information.
The problem is present in releases 9.2.0.3, 9.2.0.4 and 9.2.0.5 and reported as being fixed in releases 9.2.0.6 and 10.1.0.3.
Solution or Workaround
Select an option below:
  • Upgrade to Oracle release 9.2.0.6/10.1.0.3
  • Set the following Oracle event in the init.ora file:
    event='10235 trace name context forever, level 2'
    Once enabled the geometric network builds successfully.
Article ID:000007741
Software:
  • ArcMap 9 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
