English
How To: Silently install the tutorial data
Summary
Instructions provided describe how to run the setup from a command line and install the ArcGIS 9.0 tutorial data silently (without any user intervention). See the install guide for other products that can be installed for additional command line options or see the link in the Related Information below.
Procedure
Run the following command from the command line to perform a install of the tutorial data:
Code:
msiexec.exe /i <path to setup files>\tutorial.msi /qb
Related Information
