English
Error: Failed to connect to the specified server. Bad user login
Error Message
Before downloading ArcSDE 9.0 Service Pack 3, it was possible to use "" as a username and password from ArcCatalog in ArcSDE 9.0 and SQL Server if the SQL Server instance had BUILTIN\ADMINISTRATORS as a Windows Group.
After downloading ArcSDE 9.0 Service Pack 3, logging in with "" as a username and password returns the error message:
"Failed to connect to the specified server. Bad user login"
Cause
This is a known issue.
Solution or Workaround
Use a valid username and password to log in, and avoid using "" to log in.
    Related Information
