English
Bug: ArcSDE Direct Connect on UNIX systems leaves files in /tmp
ArcSDE Direct Connect on UNIX systems leaves files in /tmp. This issue is addressed in ArcSDE 9.0 Service Pack 3 (SP3), except that ArcSDE Admin commands will continue to leave files in /tmp.
Cause
This is a known issue.
Workaround
To address this issue:
  1. Download ArcSDE 9.0 Service Pack 3 (SP3) from the link in Related Information, below.
  2. If files remain in /tmp, as they do when using ArcSDE Admin commands, delete all files in /tmp with names like *FIFO* when no ArcSDE connections are in progress on the machine.
Related Information
