PROBLEM
Lines and shades appear transparent or streaky
Some lines and/or polygon fill shades appear transparent or streaky.
Cause
The linesets and shadesets such as PLOTTER are 'stroked' symbolsets. The shade/line is potentially not completely opaque, allowing underlying features to display through.
Solution or Workaround
Use SHADEPEN and SHADESIZE or LINEPEN and LINESIZE to assure that stroked symbols are wide enough to eliminate the streaky appearance. A good rule of thumb is to set LINEPEN = LINESIZE (or SHADEPEN = SHADESIZE). Continue increasing the size of these parameters if problem persists as the 'stroke' of the symbol may still be too narrow.
    Article ID:000007695
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
