HOW TO
This article describes how to change the labels and descriptions for the geocoding input boxes in the HTML viewer. These text fields are generated dynamically by a function in the HTML viewer that parses the response sent from ArcIMS.
The content of these text fields is dependent on the type of address style used in the map service. For example, if the US Address with Zone style was defined for a particular map service, then the labels that are returned for the input boxes would be:
<TAG id="ZONE" label="Zone" width="5" type="text" description="zone information" />change to....
<TAG id="ZONE" label="Zip Code" width="5" type="text" description="US Zip Code"
Warning: Always stop the services in the following order, to avoid possible corruption of the configuration files: 1. ArcIMS Tasker 2. ArcIMS Monitor 3. ArcIMS Application Server
Warning: Always start the services in the following order, to avoid possible corruption of the configuration files: 1. ArcIMS Application Server 2. ArcIMS Monitor 3. ArcIMS Tasker
Get help from ArcGIS experts
Download the Esri Support App
