PROBLEM
After installing Service Pack 2 for Windows XP (SP2) and/or Microsoft security patch MS04-44 (KB885835), ArcView 3.x clients' reading files hosted on network file servers may experience very slow response times. This problem is most noticeable when reading very large amounts of data, or a large number of files concurrently across the network.
This is caused by some aggressive file locking introduced with Microsoft Security Update KB885835. The files are locked (closed) before ArcView can generate a sufficient buffer for tasks such as panning.
Warning:
The workaround given below requires editing the registry. Before editing the registry it is recommended that you make a backup of the registry and know how to restore it. For more information about how the registry works see Microsoft Knowledge Base article #256986.
ESRI does not assume responsiblilty for errors resulting from executing the procedures described in the article. Proceed at your own risk.
Get help from ArcGIS experts
Download the Esri Support App
