HOW TO
Enable store relative data sources the default in ArcMap
Summary
Instructions describe how to enable 'store relative data sources' as the default in ArcMap.
Procedure
Follow the instructions below.
  1. Add and save the following code to the normal.mxt file; ThisDocument in the VB editor.
    Code:
    Dim pMxDoc As IMxDocument
    Set pMxDoc = Application.Document
    pMxDoc.RelativePaths = True
Article ID:000007643
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
