HOW TO
Instructions provided describe how to change the number of decimal places displayed in the Edit Sketch Properties and Attributes dialog boxes.
When the Edit Task is Modify Features, the Edit Sketch Properties dialog box displays vertex coordinates with the number of decimal places specified in the above setting.
In the Attributes dialog box, this setting affects only Double data type values. All the decimal places for Float data type values are displayed regardless of the number of decimal places in the 'Display measurements using [ x ] decimal places' setting.
This setting has no effect on the number of decimal places displayed in the layer attribute table. The layer attribute table column headers give access to the settings for column formatting.
Get help from ArcGIS experts
Download the Esri Support App
