PROBLEM
Webroot Spy Sweeper software can cause Python geoprocessing scripts to fail in ArcGIS
Built-in scripts, such as 'Raster to Geodatabase (multiple)', or custom scripts added to a toolbox fail with:
Executing (RasterToGeodatabase_4): RasterToGeodatabase C:\temp\12t185615 "Database Connections\Raster.sde\Raster.RASTERDB.Ortho2004Color" # "Database Connections\Raster.sde\Raster.RASTER.Ortho2004Color"
Start Time: Tue Nov 16 14:16:20 2004
Running script RasterToGeodatabase...
Error in script RasterToGeodatabase.
Error in executing: cmd.exe /C C:\PROGRA~1\ArcGIS\ARCTOO~1\Scripts\RASTER~1.PY "C:\temp\12t185615" "Database Connections\Raster.sde\Raster.RASTER.Ortho2004Color" "#" "Database Connections\Raster.sde\Raster.RASTER.Ortho2004Color"
Cause
Webroot's Spy Sweeper Enterprise software is installed and is not allowing scripts to process.
Solution or Workaround
  1. Open Webroot Spy Sweeper.
  2. Open Options.
  3. Select Active Shields.
  4. Disable Spy Installation.
Article ID:000007585
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
