English
Error: Raster to Polygon (Point, Polyline) tool fails to execute after processing for some time
Error Message
When converting a raster with many cells to polygons with the Raster To Polygon tool, it fails and displays the following error message:
"An error was encountered while executing spatial_RasterToPolygon.
Failed to execute (RasterToPolygon_1)."
This also applies to the Raster to Point and Raster to Polyline tools.
Cause
The output shapefile being created is approaching the 2.1GB limit for shapefiles.
The output shapefile is written to disk during processing. This allows the monitoring of the completed amount.
Solution or Workaround
Use either option below:
  • Use RESAMPLE the create a coarser or lower resolution version of the raster that can be converted successfully. As the raster is resampled down, fewer features are required to represent it. At some point, the size of the output shapefile falls below this limit.
  • Use CLIP to split the raster into smaller pieces. These smaller rasters can be converted and processed individually.
Related Information
