English
Error: Failed to rename the specified file [RasterDataset]
Error Message
After specifying an output raster name, the following error message may appear:
"("esriDataSourcesRaster.RasterDataset") Failed to rename the specified file"
Cause
In certain cases, using an output raster name with characters other than a letter or digit may report this error.
Functions which are known to do this include Create Raster, Cut/Fill, and Zonal Geometry.
Solution or Workaround
For output raster names, only use the letter (a-z), number (0-9), or underscore (_) characters.
It is not recommended to use other characters beyond these when naming rasters.
