ERROR
This control requires an ESRI Designer license
Error Message
When developing applications that use the ArcGIS developer controls, if the control is dropped onto a form, the following error message appears:
"This control requires an ESRI Designer license. Remove this control from your project."
Cause
The ArcGIS Engine Developer Kit product is not installed and authorized on the machine.
ArcGIS Desktop installed the following controls:
-MapControl
-PageLayoutControl
-GlobeControl
-ReaderControl
-SceneControl
-TOCControl
-ToolbarControl
An ArcGIS Desktop license only allows the development or design of applications with the MapControl and PageLayoutControl controls.
The remaining controls are licensed for ArcGIS Engine and can only be used to develop if the ArcGIS Engine Developer Kit is installed and authorized.
Solution or Workaround
ArcGIS 9.0 & 9.1
Purchase the ArcGIS Engine Developer Kit product and authorize the machine to develop with any of the following controls:
-GlobeControl
-ReaderControl
-SceneControl
-TOCControl
-ToolbarControl
For more detailed information on how to use each of these controls and which license is needed for each, refer to the ArcGIS Developer Help. For example, the 'TOCControl CoClass' help topic says that this control's availability is with the ArcGIS Engine product.
    Article ID:000007505
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
