English
How To: Programmatically embed fonts when exporting a map to PDF
Summary
Instructions provided demonstrate how to programmatically embed fonts when exporting a map to PDF format.
Procedure
  1. Start ArcMap.
  2. Open the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  3. In the Project Explorer window, expand Project.mxt and select ArcMap Objects > ThisDocument then right-click and select View Code.
    [O-Image] Visual Basic Project  Explorer
    Code in the Project's ThisDocument code module will only run in the current map document. To store the code in all map documents open the Normal.mxt ThisDocument code module instead.
  4. Copy the following code into the code module.
    Code:
    Sub exportPDF()
    Dim pMxApp As IMxApplication
    Dim pMxDoc As IMxDocument
    Dim pActiveView As IActiveView
    Dim pPageLayout As IPageLayout
    Dim pExporter As IExport
    Dim pExporter2 As IExportPDF
    Dim pPrinter As IPrinter
    Dim pRECT As tagRECT
    Dim hDc As OLE_HANDLE
    Dim pDriverBounds As IEnvelope
    Dim pVisibleBounds As IEnvelope
    Dim pPixelBounds As IEnvelope
    Dim ipPixelBounds As IEnvelope
    Dim width As Double
    Dim height As Double
    Set pMxApp = Application
    Set pMxDoc = ThisDocument
    Set pActiveView = pMxDoc.ActiveView
    Set pPageLayout = pMxDoc.PageLayout
    Set pExporter2 = New exportPDF
    Set pExporter = pExporter2
    Set pPrinter = pMxApp.Printer
    Set pVisibleBounds = New Envelope
    Set pVisibleBounds = Nothing 'set to nothing unless clip to graphic extent is checked
    Set pPixelBounds = New Envelope
    pExporter.ExportFileName = "C:\temp\PDFexport.pdf"
    pExporter.Resolution = 300
    pExporter2.EmbedFonts = True
    pPrinter.QueryPaperSize width, height
    pRECT.Left = 0
    pRECT.Top = 0
    pRECT.Right = width * pExporter.Resolution
    pRECT.bottom = height * pExporter.Resolution
    pPixelBounds.PutCoords pRECT.Left, pRECT.Top, pRECT.Right, pRECT.bottom
    pExporter.PixelBounds = pPixelBounds
    hDc = pExporter.StartExporting
    pMxDoc.ActiveView.Output hDc, pExporter.Resolution, pRECT, pVisibleBounds, Nothing
    pExporter.FinishExporting
    End Sub
  5. Close the Visual Basic Editor.
  6. Run the code.
    A. Click Tools > Macros > Macros to display the Macros dialog box.
    B. Select a macro and click Run.
