BUG
Position Vector and Coordinate Frame methods are currently unusable because the dy value (y axis translation) is not being read properly
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2) **
New GeoTransformation dialog incorrectly setting dy (y translation) param to zero.
In ArcMap, a custom GeoTransformation (datum transformation) can be defined to properly transform and project data on-the-fly. The Position Vector and Coordinate Frame methods are currently unusable because the dy value (y axis translation) is not being read properly from the dialog. It is always converted to zero.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
    Article ID:000007488
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
