English
Bug: Antialiasing effect not seen with SIMPLEPOLYGONSYMBOL or SIMPLELINESYMBOL tag when width=1
When antialiasing is set to true with SIMPLEPOLYGONSYMBOL or SIMPLELINESYMBOL tags and boundarywidth in case of SIMPLEPOLYGONSYMBOl and width in case of SIMPLELINESYMBOL is set to 1, then the antialiasing effect is not seen.
When boundarywidth in case of SIMPLEPOLYGONSYMBOL and width
is 2 or above, the antialiasing effect is
visible and works as expected.
Cause
When the boundary width/width =1, then antialiasing is not effective - the spatial server is not processing this correctly.
Workaround
There is no workaround for boundary width/width=1 in current releases. The alternative is to use boundary width/width =2 or above.
    Related Information
