English
Bug: JavaDoc, or Java API Web control documentation, is updated to reflect changes to file handling and geocode bug fixes
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2) **
JavaDoc, or Java API Web control documentation, is updated to reflect changes to file handling and geocode bug fixes.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
Service Pack 2 provides updated Java API web control documentation to accompany the following fixed bugs:
a) Changed file handling to a more standard configuration to allow for future support of more application servers, and enable deployment of unpacked WAR files.
b) For some geocoded points, the spatial reference was not correctly applied, causing the geocoded point to not appear on the map, or appear in the wrong location. This fix ensures that the spatial reference is always applied to the geocoded point.
c) The Java ADF Web controls no longer depend on arcgis_jcs.jar.
d) Change to allow for support of Java ADF Web controls in a portlet environment.
e) The Java ADF Page Layout Template has been updated to correctly display scale dependent layers in the table of contents.
Related Information
