English
Error: Unable to run lmutil.exe
Error Message
When trying to setup the License Manager, after the license file is specified the following error message can occur:
"Unable to run C:\DOCUME~1
\username\Local Settings\Temp\LMUTIL.EXE. Error status: 0"
Cause
This error can occur if the TEMP or TMP paths are too long.
Solution or Workaround
Follow the steps below to change TEMP and TMP environment variables to a short path.
  1. Go to Control Panel > System, and go to the Advanced Tab.
  2. Click the Environment variables button.
  3. Locate TEMP and TMP under User Variables. Use the Edit button and change the value from its current value, such as
    %USERPROFILE%\locals~1\TEMP, to a short path on the root of C:, for example, C:\TEMP.
  4. Verify both values are set to C:\TEMP, verify that C:\TEMP exists and reboot.
    Warning:
    Be sure that the directory exists before rebooting, otherwise errors will occur.
  5. Attempt the setup again. This time the error should not occur.
