BUG
Export CAD: Crashes if Layer and Lyrname fields in your table have different values
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2) **
If there are two fields in the table, one called Layer and one called LyrName, and the two have different values, the one called Layer should be used, unless Layer is blank.
If Layer is populated, LyrName becomes a single space, and LyrName takes precedence.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
    Article ID:000007440
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
