BUG
Custom VBA toolbar does not persist in normal.mxt
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2) **
A custom VBA toolbar does not appear in the Customize dialog toolbars list when it is invisible upon save in the last ArcMap session.
If you create a custom toobar to the normal.mxt or the current document and add some buttons or other...then, before exiting ArcMap, you remove this toolbar from the GUI, the next time you open ArcMap, that toolbar is gone. It is no longer in the list of available toolbars when you right-click on the toolbars or select Tools > Customize, Toolbars tab.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
    Article ID:000007418
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
