BUG
Web Controls are not working in the State Server environment
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2) **
Web Controls are not working in the State Server environment. Developer are prohibited from using separate state servers.
When a remote State Server is used with the templates:
UseMimeData=true
No images shows up at runtime for MapViewer application - all links are broken.
UseMimeData=false
runtime - MapViewer application images shows up fine, but when you try to do Map navigation it throws application error - session has timed out.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
    Article ID:000007414
    Software:
    • ArcGIS Server
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
