BUG
After defining a custom geographic (datum) transformation, the results are incorrect or a dataset doesn't line up properly with other data.
The Y translation (dy) transformation parameter is always set to zero by the transformation process. This parameter can be viewed in the status text at the bottom of the dialog.
Get help from ArcGIS experts
Download the Esri Support App
