PROBLEM
Data in DHDN-based coordinate system cannot be transformed
Data using a coordinate system that includes the DHDN definition cannot be transformed using the existing geographic (datum) transformations.
Cause
The name of DHDN was corrected in the Projection Engine library version 9.0. The old, incorrect names are:
GCS_Deutsche_Hauptdreiecksnetz and D_Deutsche_Hauptdreiecksnetz .
The new, corrected names are:
GCS_Deutsches_Hauptdreiecksnetz and D_Deutsches_Hauptdreiecksnetz.
The predefined geographic transformations expect the corrected DHDN name, so an old DHDN definition does not match the transformation definition.
Solution or Workaround
Download and install ArcGIS 9.0 Service Pack 2.
If using ArcSDE, download and install ArcSDE 9.0 Service Pack 2.
    Article ID:000007379
    Software:
    • ArcMap 9 x
    • ArcGIS Engine 9 x
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
