BUG
Error "Syntax error in field definition" when using Copy Rows to copy a table view with a join
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2) **
Starting with a model that does an AddJoin of two table views, the output tableview from addjoin is then added as input to MakeTableView.
Using Copy Rows to copy the output table, the following error occurs:
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
    Article ID:000007361
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
