English
Error: Error 1904 module C:\Program Files\ArcGIS\Bin\BpESEIFunctions.dll failed to register HRESULT -2147220991
Error Message
During the installation of ArcGIS 9.0 on a Windows 2000 system, the following error message or similar may occur:
"Error 1904 module C:\Program Files\ArcGIS\Bin\BpESEIFunctions.dll failed to register HRESULT -2147220991"
The filenames may vary.
Cause
Windows 2000 fails to register files because it lacks the necessary registry space to add the registration information; this happens when reaching maximum limits.
Solution or Workaround
Increase the available registry space.
  1. Navigate to Start>Control Panel>System to open System Properties.
  2. Select the Advanced Tab, click Performance Options and click Change in the Virtual Memory section.
  3. Increase the current value for the maximum registry size by adding an additional 100 MB to the current maximum.
  4. Click OK to save settings and then exit System Properties.
  5. Re-run the installation.
