English
Bug: Characters do not export correctly to PDF or EPS
** This issue will be addressed in ArcGIS 9.0 Service Pack 2 (SP2) **
Characters in the Windows encoding range of 128 to 255 do not export correctly to PDF or EPS. This problem occurs with TrueType fonts when embedding is turned on, and with Type1 fonts with embedding set to on or off.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
    Related Information
