BUG
Export to script does not ignore derived parameters
** This issue will be addressed in ArcGIS 9.0 Service Pack 2 (SP2) **
If the last parameter in a model is derived, an extra comma is added at the end of the script. This is usually not an issue with Python scripts (as long as there is no more than one derived parameter), but it will cause VBScripts to crash.
Cause
This is a known issue.
Workaround
** This issue is addressed in ArcGIS 9.0 Service Pack 2 (SP2).
Click on the link in Related Information below and download Service Pack 2, if necessary. **
If ArcGIS 9.0 Service Pack 2 is not available, manually delete the last comma in a text or script editor.
    Article ID:000007322
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Related Information
    Discover more on this topic
