PROBLEM
Exported animations do not appear correctly
Colors in exported animations from Tracking Analyst may not appear as they do in ArcMap.
Cause
Tracking Analyst degrades the display going to the codec to a 256 color image. This is done to increase the success of creating the AVI with the most codices.
Solution or Workaround
Select one of the options below.
  • Use the Frame Image Engine animation format.
  • Select a color that is more accurately converted to 256 color image.
Article ID:000007262
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
