BUG
Incorrect results returned when running a report for the US using ArcGIS Business Analyst 8.3
Running a report gives incorrect results when the boundary layer is a States layer in the Business Analyst Reports wizard.
Cause
This is a known issue.
Workaround
Follow the workaround below.
Select 'None' as the boundaries layer in the Business Analyst Reports wizard dialog box.
Article ID:000007244
Software:
  • ArcGIS Business Analyst Desktop
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
