English
Bug: Geocoding reference data with Z values generates geocoding results with null geometries; does not display results
When using a geocoding service created with reference data that has Z or M values to geocode addresses, the geocoding results contain a null geometry value. They do not display in ArcMap or in the preview pane of ArcCatalog.
Cause
This is a known issue.
Workaround
This was not an issue with ArcView 3.X and is no longer an issue with ArcGIS 9.x release. To resolve the issue, upgrade to an ArcGIS 9.x release.
