BUG
'Examine all file extensions' option does not enable Microstation files with non DGN extensions to be listed
Microstation files can be created with file extensions other than DGN. These files can be recognized by ArcGIS by checking on an ArcCatalog option found under Tools > Options > CAD tab > Examine all file extensions.
At version 9.0, checking on this option does not allow the files to be listed.
Cause
This is a known issue.
Workaround
Place a recognized CAD format file with a standard DWG, DXF or DGN extension in the same folder as the other Microstation files. Refreshing the directory now lists the additional Microstation files.
    Article ID:000007227
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
