ERROR
Error adding element
Error Message
In ArcGIS 9.0 or later, when creating or editing annotation features or simple features with related feature-linked annotation in a personal geodatabase with a version of 8.3 or older, the following error message displays:
"Error adding element. The edit that you have made is not supported in earlier versions of the Geodatabase".
Cause
Annotation was significantly updated at ArcGIS 9.0. Due to this update, annotation editing of previous geodatabase versions was blocked to prevent the creation of annotation incompatible with previous versions of the software.
Solution or Workaround
Upgrade the personal geodatabase, so that the geodatabase version matches the ArcGIS version currently running.
  1. For more information on how to upgrade the geodatabase, see the ArcGIS Desktop help topic 'Upgrading a geodatabase.'
    Warning:
    It is not possible to view any of the data with an earlier version of ArcGIS if the geodatabase is upgraded to a current version.
Article ID:000007215
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
