BUG
A system error has occurred. Error Details: "not available" when using Data Delivery Extension
After setting up the Data Delivery Extension with ArcIMS and submitting a translation request in the viewer, instead of the translation results, the following error displays:
"A system error has occurred.
The translationServlet log file shows an entry similar to the following:
Code:
<date/time> ERROR Exception class is: java.lang.NullPointerException
Cause
This may be due to a non-unicode locale being used. The ArcIMS Data Delivery Extension 9.0 is not fully supported with non-English locales.
Workaround
Switch to English locale and verify the error still occurs. If it still occurs, contact ESRI Support for further troubleshooting assistance.
    Article ID:000007213
    Software:
    • Legacy Products
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
