English
Error: When the Normal.mxt is corrupt, 'Error running VBA code: User Interrupt' is returned
Error Message
The following error occurs when using the Field Calculator:
"Error running VBA code: User Interrupt".
Cause
The Normal.mxt is possibly corrupted.
Solution or Workaround
Before performing any of the troubleshooting tasks below, create backups of the files and/or folders to be deleted.
  • Shut down ArcGIS and delete the Normal.mxt.
    Using Windows Explorer, navigate to the Normal.mxt at:
    Code:
    C:\Documents and Settings\username\Application Data \ESRI\ArcMap\Templates\Normal.mxt
  • If this does not resolve the issue, delete the ESRI folder located at:
    Code:
    C:\Documents and Settings\username\Application Data\ESRI
Related Information
