English
How To: Edit or move annotation stored in an ArcMap document
Summary
The Default annotation class must be turned on to move or change any annotation properties in the map.
Procedure
  1. Select View > Data Frame Properties and select the Annotation Groups tab.
  2. Check the box for <Default> under Group Name to turn it on.
    Properties for annotation stored in other groups in the map will now be editable.
