English
Error: The version could not be reconciled. Underlying DBMS error
Error Message
Reconciling a child version against its parent version returns the following error:
"The version could not be reconciled. Underlying DBMS error
Violation of UNIQUE KEY constraint 'sde_logfiles_uk2'.
Cannot insert duplicate key in object 'SDE_logfiles'."
Cause
The Permission property on the parent version is set to Protected.
Solution or Workaround
Change the parent version Permission property to Public.
