English
Error: ArcCatalog.exe has generated errors and will be closed by Windows
Error Message
ArcCatalog fails to start and returns the following error:
"ArcCatalog.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created."
Cause
This is a known issue.
Solution or Workaround
Delete the normal.gxt and ArcCatalog.gx file. These files will be re-created the next time ArcCatalog is started.
  • Windows 2000 and XP:
    Code:
    C:\documents and settings\<YOURLOGIN>\Application Data\ESRI\ArcCatalog
  • Windows NT:
    Code:
    C:\WINNT\Profiles\<YOURLOGIN>\Application Data\ESRI\ArcCatalog.
Related Information
