BUG
Open Attribute Table returns no values on a geodatabase point feature class with a join and a definition query based on a joined field
Open Attribute Table returns no values on a personal geodatabase point feature class joined to a .dbf table and a definition query is applied based on a field from the joined .dbf.
Cause
This is a known issue.
Workaround
Perform the join and then save the data to a new shapefile. Then set the definition query.
    Article ID:000007166
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
