English
Error: Linestring or poly boundary is self-intersecting
Error Message
When converting SDC data to SDE by way of ArcCatalog, the user may receive the following error:
"Linestring or poly boundary is self-intersecting Failed to execute (CopyFeatures)".
Cause
SDC data cannot be converted to SDE geodatabase format by way of ArcCatalog.
Solution or Workaround
Follow the workaround below:
  1. Export to personal geodatabase.
  2. Use ArcCatalog to Paste the feature class into the ArcSDE geodatabase.
Related Information
