BUG
Survey Analyst unable to read RAW header information
The SDR and TDS converters are not able to read linear units in the header information for RAW (.raw, .rw5) files.
Importing these files into a Survey Project will update the SurveyDataExchange log with the following message:
"INTERNAL ERROR: Failed to parse header data. Error: 0x080004005"
Cause
This is a known issue.
Workaround
Currently, there is no known work around.
In some cases, increasing the spatial domain prior to the import may permit data to load.
    Article ID:000007159
    Software:
    • ArcMap 9 x
    Get help from ArcGIS experts
    Contact technical support
    Download the Esri Support App
    Go to download options
    Discover more on this topic
