ERROR
Failed to create object. Make sure the object is entered in the system registry
Error Message
Attempting to insert a Microsoft Word document into a layout may yield the following error message:
"Failed to create object. Make sure the object is entered in the system registry"
Cause
The machine's anti-virus software may have "script blocking" enabled.
Solution or Workaround
Adjust anti-virus software so that it does not conflict with the insert object function in ArcMap.
  • Contact the Anti-Virus software provider for assistance in modifying the script blocking settings.
  • Access the Symentac support site through the link Related Information and navigate to information about changing the script blocking settings for Norton Anti-Virus.
Article ID:000007145
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
